I’m slipping deeper into this detailing thing...
Last time I cleaned my car I spent ages doing the wheels. I pressure washed them, squirted them with diluted Valet Pro Bilberry wheel cleaner, agitated with everything from wheel woollies to an old paint brush, pressure washed again, shampooed, washed again, then dried.
Sure they were clean but they weren’t as clean as I felt they should be given the time investment.
The LED me to recently buying some Valet Pro Dragon’s breath iron remover I wanted to try. So, accompanied by my two trusted assistants (5 and 4) I set about washing the car.
Before...
First job was the wheels. I pressure washed, cleaned, and gave them the full Bilberry treatment. I then washed it all off too see what I was left with.
This picture is having just applied the wheel cleaner.
It looked pretty clean after but still not as bright as I wanted, so I broke out the Dragon’s Breath, suitably decanted into a squirty bottle.
Once squirted onto the wheels I left to dwell (on essentially very clean wheels) and came back to this...
I must admit this was quite impressive! I then agitated this with a brush and cheapy noodle cleaner.
Then it was back to conventional washing.
Snowfoam has been on the car for some time before I got round to the picture, hence why it’s not very snowy.
Two bucket wash method followed then I dried the car. Results below.
Close up of far cleaner wheels...
I’m chuffed with the result, plus it got my boys and me out in the fresh air for a few hours.
The detailing bug shows no sign of loosening its grip!
  • Like 5
:) I use a foam with tfr in it as it gives it a bit more effectiveness, it does make it less foamy though. Worth noting with iron remover (fallout remover) that it doesn't remove the core metal. It dissolves rust that has formed around the iron allowing you to more easily mechanically remove it with clay etc.
Great result!
Love my detailing it gives such a sense of satisfaction. I have started to build quite a collection in the shed with various waxes. It becomes really addictive.
Here's my old boat after a few cleans. dc83fd2dcafa01246538510e412fa6b5.jpg20170321_141056.jpga6d37e4dd37e2cabedc4bf2d4e141f21.jpg
Sent from my SM-G935F using Tapatalk
Be careful with TFR - not really supposed to be a regular thing.
Degrades LSP and is a common cause of sill corrosion.
Snow foam - providing its something like BH autofoam should be more than enough tbh
On a side note - those wheels weren't even that bad:
