 IS220d....Ok the egr system needs cleaning now and again but what I would like to know is the egr pipe where it meets the block is that a straight channel thro to the cooler on the other side of the engine and if so should this not be part of the clean and maybe all the parts linked..cooler,actuator etc??
Based on the position of the cooler and metal pipe, I would be surprised if it wasn't a straight channel.
I suppose in theory the whole thing should be cleaned, but having seen the location of the EGR cooler, I can definitely see why this isn't the case! :smile:
I gather the exhaust manifold would need to be removed the get it all out?
Was actually hoping to get the turbo off yesterday but with the snow and a bout of manthrax it aint happened..will take plenty o pics tho when it does..probably whip the egr cooler off too to inspect!
