Hi
I've been doing some searching without any success. My 95 LS400 has failed cd player illumination bulbs. The unit itself is functioning correctly. I managed to find some information about a repair procedure but all the links are dead. Has anyone got the document?.
Arrrr...now I understand.
By any chance are all the lights out on the climate control buttons as well? If so this is a known fault within the head unit caused by dry solder joints on a couple of components.
Hi Steve
The climate controlled unit is working perfectly and it's well illuminated. Just the illumination on the stereo, I would assume the bulbs have failed ? Just be nice to have a how to guide if there is one avaible
Thanks for repsonce
This is a known fault on these head units -  mine does it but they come on as the interior warms up.
The bulbs rarely fail, and only ever the odd one, so if none work it is the supply - which is usually the capacitors as mentioned above.
There are tutorials on youtube and Lexus websites about it, but you have to be a confident at soldering - getting the unit out is not a big job.
There are also firms that offer a repair service.
Just to add,
There is a Wheeler Dealers episode you can likely find on YouTube of an LS400 where the display was refreshed using a kit.
Worth a viewing regardless.
