Hi all
Just checked my locking wheel nut case in the glove box , there is only one master key ? But the preform insert has space for  two . Do Lexus only supply one or have i got one missing.
Cheers Steve
As far as am aware its usually only one locking wheel nut key,however you should also have the locking wheel nut key number in your service history book just in case you need to order a replacement,hope this helps
46 minutes ago, ST100 said:
Hi all
Cheers Steve
Only one in both my cars as well - all the wheel locking nuts are the same on a particular car.
Cheers guys
Got the code number , thanks for the info , my old car came with two master keys so i thought one was missing
Cheers Steve .
