Only thing I cannot understand is how the final trim is fised to the cut exhaust... By means of these 3 holes???
Andrew, can you please let us know?
Thank you
Thank you
That bracket was not used. As per PM I used a sheet of steel and made a template and effectively made a "blanking plate" that replaces it and cut a hole, welding some steel pipe, flared it a little and used it as a sleeve finished off with an exhaust clamp.
