Hi
When I am about to go on an extended tour I like to load up the SatNav with the places I will be visiting and staying and the easiest way of doing this is to use the Postcode entry for the SatNav. But I have found no way of then re-naming the postcode label in the SatNav destination list to something that is more meaningful. Anyone know if this can be done? Currently I carry a paper list that allows me to see what postcode is where!
I would love to crack this one.
Richard
Enter the postcode and save. Next go to my memory, memory points, register, select previous destinations and select the post code you entered, OK, then edit and you can then edit the name and location.
You can register 500 places. You can also register them to them to the 5 quick access points next to the home button
Many thanks John. I have spent hours studying the handbook trying to do this.
I got the official handbook from Lexus but still not easy to read as you are kept referring back to other pages. Why they just cannot just say ‘do this’ rather than see this page and then see that page I do not know as it is just confusing.
