I blew the ign and inj  fuses whilst jump starting the car. I replaced the fuses and it starts fine but the steering column does not move into its set position when I put the ignition key in and the steering is heavy. The dashboard warning lights do not flash up when the ignition key is turned. I think another fuse must have blown but I checked all the fuses in the boot, drivers side and under the bonnet. Can anyone help to identify what component has failed!
thanks
Keith
Ouch! Lucky the main 160A fuse didn't blow.
Taken from the US site but it looks as though there are two fuses 6 and 18 that need to be checked, drivers and passengers side kick panels.
