Hi, I hope this is the correct place being a new member.
Some help please, I can't open the car using the door handle lever when locked car stopped in neutral or P , currently I have to use the unlock button on either the drive or passenger door. I,ve sat in the car and pressed the open and lock button for the beep to open all doors from out side but cannot solve inside?
Have you got your owners book. It covers in there all the different configurations for door locking and unlocking.
Page 19
Yes I do but it's like reading spaghetti, i,ve tried  all the combo's but I think i've completely messed it up!, aw well try again
On 9/29/2017 at 9:50 PM, lordksmith said:
Job done good old utube
which utube video helped you solve the issue?
sorry goodfella1 i just searched IS-250 SE-I   and scrolled through, sorry can't remember which one it was a girl though, left hand drive.  in a nut shell get in ignition on (not engine running)
put car in N press and hold the lock button ,locks will lock then unlock . back into p ignition fully on engine running put into R the doors lock ,back into P doors unlock.
