1 minute ago, bobmc said:
love the updates rob, fantastic work :thumbsup:
Thanks matey 👍
More photographic filth from Rob; can this not be banned?
7 hours ago, bobmc said:
Haha 'lexerotica' lol😁
New word right there 😂
Had few more parts turn up and  had a day off today so cracked on with it...
New air con condensor came, got a quote off the dealer for over £230! This cost me just over £80 so quite a saving.
Wanted to be stealthy looking like the factory 1 so gave it a quick spray with some satin black.
Compared to the old 1....
Looks so much better now!!
My alternator belt also turned up so that got thrown on. Also fitted my sparkplugs, went for NGK iridiums heat range 8 ready for some boost.
20181003_153654.thumb.jpg.142632a57ecd591c8f61e739f34adcd7.jpg20181003_180059.thumb.jpg.e462fdc58ee7db42926b504d71addd8d.jpg
Next up was the radiator, i ordered a mishimoto for some extra cooling and the original had a slight leak on it. Looks stunning!20181003_164444.thumb.jpg.9a9e77ca202b9750c5b1670bc0250b6b.jpg
I then gave the fan cowling a good clean up and got that fitted.
20181003_163747.thumb.jpg.6458a21366f52b42b1921045eb5b1255.jpg20181003_163804.thumb.jpg.69aa450cca3109c8b0ece34a9f574ea7.jpg20181003_164838.thumb.jpg.eba2a89e951ee341b42e39c86b637c57.jpg
Now this is when i ran into a small issue, the fan cowling was hitting the crank pulley when fitted due to the extra size of the pulley.20181003_172258.thumb.jpg.8ebe9188781d9c7435ec3b22ff8f013e.jpg
Luckily it was only a small part of the plastic so pulled it back out and trimmed it down with the dremmel. No pictures of this but now it has around 8-9mm of clearance. So with the radiator in and condensor fitted i then had to freshen up the horns as these was looking weathered. Quick clean up and some satin black and they was looking fresh again.20181003_160251.thumb.jpg.8bff884307d4dd388e79cb42d14af2fa.jpg20181003_210706.thumb.jpg.61b875c501ca72cb6077813a8e329a35.jpg
And now the final pictures of it in the bay, getting excited now! Feel like ive got so much done and looking so much better, front panel will also be painted at some point and it has a couple of rust spots.
Enjoy 🤤
20181003_182459.thumb.jpg.73c7f7f6549ab2bb3253a9b3269aa53c.jpg20181003_182511.thumb.jpg.8bf18b7af1d0b8e75c630dad7a71772a.jpg20181003_182551.thumb.jpg.b3b24fc02836b1d09679511a37303f25.jpg20181003_182439.thumb.jpg.806aa0cb50d96dedf3c68bfe7d2a5abd.jpg20181003_182633.thumb.jpg.dbece63c854d12f3f06b17577af3c78e.jpg20181003_182425.thumb.jpg.9840b13fd2b8c871558fcbaace58cb4a.jpg
  • Like 7
13 hours ago, TigerFish said:
Looks awesome dude
Sent from my iPhone using Tapatalk Pro
Thanks TigarFish 👍
13 hours ago, SpeedyGee said:
Coming together nicely buddy 👍
Cheers muka 👍
Woaw, i have missed a few updates but this is coming along really nice!! Top notch work!
Thanks matey 👍
I'm amazed you kept those weedy "meep-meep!" horns. They are terrible, the worse I've had on a car, and I've had a Marina!
Then again, I guess you can let the turbocharged 2JZ do all the talking. 😁
Nice update Rob. No matter what the obstacle you just overcome it. This build should have its own video channel.
Will you run the car before adding the body kit or complete the whole thing before the launch?
😂😂 yeh the blow off valve would probably have more of an effect
I have really thought about doing a vlog of sorts but the black country accent sounds horrific on camera 😂 i will probably get it running 1st with just the base map then once all the kit is on and complete i will get it tuned
Aah, don't worry about it. I don't know why people have such a downer on the black country accent. We'll miss regional accents when they're gone.
Anyway, can't wait for your UK tour to show us all your handiwork. 😉
Tell me about it i cant wait either, interested to see how it will do down santa pod but it wont be directly set up for drag racing. I hoping to do a couple of trackdays in it aswell...... with the boost turned down a little
You do the pictures and we’ll find a voice for the ‘lexerotica’ channel.
  • Haha 3
Little update, ive had a change of plan with the project.........
So this was the original plan i had body kit wise but ideas have changed.
Im thinking of keeping the body standard looking. Now i may struggle getting the power down but im thinking it may be possible to get a 265 wide sticky tyre on 9.5 inch wide rim.
The more and more i look at pictures of a standard body IS300 lowered the more i feel its the right thing to do.
On another note i have sorted the down pipe, i ordered a down pipe off topspeed pro.
This pipe is designed for a left hand drive car so it was a risk as i have the manifold 1 side and the steering column the other side to contend with. A quick trial fit shows its not going to fit but......... the down pipe came with a vband flange..... problem is my BW s364 turbo has a marmon style flange. So i ordered a marmon flange off eBay to get welded on, turns out by welding the marmon onto the vband it made it fit absolutly perfect!!!!
20181011_164948.thumb.jpg.42c7758c179b59937ba09ca59c3bbcd7.jpg20181011_164956.thumb.jpg.43f9175796be4fac83a0b63ef636f274.jpg20181011_164053.thumb.jpg.e26fda4b2d4c59c13c023195ae7cdea9.jpg20181011_164043.thumb.jpg.ff232f5436a133fe074131d9a2f87aa3.jpg20181011_164033.thumb.jpg.c70f8cc2aefa3db456345b525ca77074.jpg20181011_180258.thumb.jpg.34ef37974d8b93d76e87777229fd79e4.jpg
in the 2nd picture you can see just how close it is to the column, this has pretty much the same gap the other side to the manifold.
All i have to do now is get it joined upto to the center section with the 3 to 4 inch flare.
This then gave me a new problem, the heater matrix hose was now touching and in the way of the down pipe.
I had a couple of bits of spare coolant hose about as i had removed the transmission cooler and replaced another pipe. So had a play with these bits of spare pipe and cooked this up
Almost bang on just need to join the 2 together.
Then throwed it back on to test it. Perfect 👌 just need some heat protection for it now.20181019_120920.thumb.jpg.0a2e2492aa3a41949c7130650cf58ea4.jpg
  • Like 6
This is a brilliant thread, just spent a bit of time reading from page 1, credit to Rob for this - definitely would like to see the end result... :kewlpics:
Nice work again Rob, dispensing with the body-kit plan must bring the launch day forward a little.
Would you please confirm receipt of my IS300 2JZ GE NAT #No compromise 2019 calendar order?
Thanks buddy, ive always loved project threads what ever forum ive been on especially the in depth 1s, always wanted to do 1 myself and this is finally my turn. Hope the work im doing helps others along the way with what ever they may be doing
Cheers muka, yeh it should do and also free up a little cash for something else aswell. Just hoping it sells easy.
You have just planted a seed for me, i might get 1 made up off 1 of those websites and bang it up in the kitchen before the mrs hangs 1 up 😂
Awesome work there mate that's going to be an absolute beast! I'd personally be putting that kit on just had a peepers at it fitted it looks immense so can only imagine what it'd be like in person I can't imagine there's many about like that either 😀
