I HAVE SAME . WHAN I STARTED LEXUS LS 430 2006  HEARED A VERY HIGH SOUND FROM ALL SPEAKERS AND AFTER THAT NO SOUND FROM RADIO,TAPE,CD HEAD UNIT IS SHOWING RADIO CHANNELS, CD , TAPE STATUS.... TRUNK 30 AM FUSE IS FINE  , HELP
Hi there
Today while starting my car , Radio voice starts with a high noise for about 1/2 min. and every thing goes silent after that until next start .... Can someone had something like that before to confirm its ML Amp.
I had mine repaired by SVT services in Edinburgh - you could ring them for advice
My point is i like to hear music as just very low dreamy background . so is it worth it to pay that kind of crazy money for repair-replace Amp. for that 15 years old car ( i like it ) . is there any easy way to hear music from ( that high end sound system) without Amp. even bypassing all that system with a another cheap even portable looks nice or even hidden one (hence that 2 days back my touch screen head unit not responding at all ) 😏
The amplifier may be uniform to other Toyota models worth doing  some research and trawling the breakers yards.
THANKS all about your nots, I was thinking to replace OEM head unit by android one. but I will not get most of benefits without audio ..... I' m thinking to get portable good Sony speaker with that android head unit instead of paying more money on that dead ML Amp , A my on the right way ?!
What about this android head unit where there is so many models in market with about 400$ ... Can i replace OEM one by this ? what about ML Amp.? can be bypassed ? or audio can work without amp ?
I've looked at the possibility of getting one, if is was simply a plug and play system I may do it but there just isn't enough info out there.  Either way you still need your amp to work.
YES The-Acre
As in some sites they said its plug and play and no need for any cutting for OME harness ... but sad to know that i still need that ML amp. to run audio😨
3 hours ago, mony61 said:
YES The-Acre
Maybe it's worth taking your amp out and seeing if you can get it repaired, most can be fixed. If I could find a UK based company for an Android unit I would get one, I'm just a bit unsure of buying one from overseas and finding it doesn't fit.
  • 4 months later...
  • 1 month later...
On 5/21/2020 at 3:35 AM, cruisermark said:
HI
On the LS430 its fuse no 21 (30A) located on driver side footwell fuse box
What problems are you having?
Hey I’m currently having the same issue you had but everytime I replace the fuse for the amp it blows as soon as it goes in or when i hook the Battery back up
I had the same issue on my 430 re blowing fuse and had my amp repaired by United Radio in NY. Internal short causes high current draw on these and hence the blowing fuse.
The repair was $475 and it was $145 to ship it back including VAT. Turnaround was pretty quick.
There is plenty of information on the US forum and the dealers in the US use this company for amp repairs.
  • 4 months later...
Hello guys, y'all seem to be great with the radio and my is that someone helps me out.
So my touchscreen in the LS 430 2001 doesn't function very well because only the upper of it actually works so it impossible to access all the other options using the touchscreen since only half of it works and whenever I turn my radio on its always says AUDIO OFF and I really don't know what to do.
  • 1 year later...
Press in the volume wheel?
  • 1 month later...
Hello I have a 2001 ls430 radio cd tape player working but no sound from any speakers
Sounds like the Amp has either blown it's fuse, or else died. Fuse is easy enough to check.
Otherwise, send the amp off to a specialist to be repaired.
The following is not a recommendation. Just what I found on t'internet. 🙂
https://svtservices.co.uk/lexus-mark-levinson-power-amp-repair-service/
