Pull the clips out of the boot lining. One nut secures each light. Twist and pull the bulb holder out. Squeeze a plastic clip that pokes through a hole and the light pops out. Doddle.
Fitting is just similar in reverse. I found the hole taking the bulb holder poor quality so it needed a little filing.
Standard bulbs are a bit dim and pinky but don't show through much when not lit. Best alternative is buy standard white bulbs and paint them red using a redcurrant colour transparent glass paint from a craft shop. This gives best red light but do show through a little more when not lit but are consistent with rear indicators.
That I do.... :P ...hold on while I try to remember the place I got them from...
I think I bought mine from here...
http://www.titanmotorsports.com/accessories3.html
But didn't pay as much as they want for them now!!!
I would try Lextasy...$38.00...not sure what shipping costs will be, but the box is small and the weight is next to nothing, plus with the current dollar exchange rate the whole lot should work out cheap as chips.....check them out on the link below.....
http://www.lextasy.com/is300_accessories_14_ctg.htm
