Hi all. I've been getting a feeling through the steering when steering right, almost like a vibration.  Doesn't  happen when steering left. Seems to drone when the speed is picked up. Probably  going to take it to a garage anyway but wondered if anyone had any ideas or pointers. Cheers
Wheel bearing would be my bet.  Or tyre out of shape. Or brake caliper.
Thanks for the reply. Bearing sounds likely as the tyres are nearly new. I'm  going on a 600 mile round trip soon so will get it checked when I return.
I mention wheel bearing because you say it happens when steering.  Generally it will be the side that sounds when steering in that direction as it puts more pressure and weight on that side. Getting it raised up and checking for play/binding/rumbling will give a good indication.
I would check the steering fluid level first and go from there.
And the answer will be pointed out when the mot is due. 😊 going to wait until then to be sure and if it is the wheel bearing I'll order a pair and do them both myself. I'll  re-post when it's done.
Ok here's  the update to the issue...It was the wheel bearing. Thanks to "the acre" for a correct diagnosis . Sourced the part and fitted it this afternoon. Quite an easy job to do as well if you are keen on the spanners. Weirdly I had an engine light come on this morning but since replacing the bearing and taking it for a drive the light has gone off. Don't  know if a diagnostic test would reveal the bearing problem  but it just seems a bit of a coincidence . Anyway , happy days and thanks again.
