Both my front seats have an ever so slight rock to them if you move your body weight about, in a certain direction. It's barely audible and very slight. I tend to notice as I get in or out the car.
I've taken a look at the bolt between the floor and rails and it's fine. Appears to be the mechanism/rails to the seat that have a slight amount of play.
Question is, is that normal? Has anyone else noticed it?
Having changed my seats, there is a surprising amount of flex in the seat rails, far from rigid. I would say it's normal but interested to get other opinions.
Mine did this and Lexus Woodford checked it over and said the seat rails were tight enough and there was nothing they could do.
Thanks for the responses guys, great to hear I'm not alone with this.
I suppose mine does this a bit too. It used to creak (solved by tightening the bolts you mentioned on the front and back of the seat rails), but there's still a bit of movement.
I'd assumed I was carrying a bit extra holiday weight... :whistling:
