I have posted in another thread about an issue with the AHBC system on the Premier model.
After automatic dipping, it does not restore the high beam until you exceed 40mph. If you turn into a narrow unlit country lane where you would not get up to this speed you end up with no visibility due to the sharp dip cutoff and no way of putting main beam on manually. As I live in a rural area, I have the AHBC switched off which is a pity because it does indeed work as described above.
