My first RX400H
Hi, i just bough a rx400h from 2007 with 79000 miles from Lexus Croydon with full Lexus history and their check before release the car. I`ve add it also 2 more years of warranty beside the normal 1 year so now will be a 3 years. I wanted to know if its worth it to go for the Lexus essential care service ? I want to keep doing service to them if it wont be a big difference between a normal garage and Lexus.With the normal garage at least where i live they all disappointed me when i went with my Toyota to them. Should i expect any problems with this car ? before i had a Toyota mr2 mk3 ( i know its a big change :smile: ) and i had only problems with it :angry:, i believe i invested in the car more than X3 compare to how much i paid for it.
Welcome to the forum.
Having Lexus service the vehicle is a kinda good idea because of the hybrid features, as part of their service they will check and annual warranty the hybrid system up to 10 years/140k miles.  But if you'd prefer to service elsewhere (a perfectly valid alternative if you have a reputable indi nearby) then the Lexus hybrid check/annual warranty can be done separately for around £65pa.
Don't worry about the Hybrid side of things too much as they are well engineered. If issues do occur say with the Battery, it can be repaired via specialists at a much reduced cost than Lexus swapping out the entire unit for £2.5k :wacko:
If you don't mind me asking, what issues did the MR2 give you?
Meanwhile enjoy your RX400h.
Don't worry about the Hybrid side of things too much as they are well engineered. If issues do occur say with the battery, it can be repaired via specialists at a much reduced cost than Lexus swapping out the entire unit for £2.5k :wacko:
Thank you very much i`m so happy , tomorrow i`ll pick it up, i`m so nervous :smile:. With my Toyota i had the next problems starting from beginning : Battery, alternator, universal joint, power steering pipe, radiator,all o2 sensors, water pump, rear parking brake, an alloy wheel cracked so i`ve bought 2 months ago a new set of nice and white alloys around 300 pounds, so every time it had a issue i repaired to make sure everything its alright ( all MOT passed without any advisory or problems )  and 2 weeks ago it started to sound like a diesel ( its a petrol ) , but only when i`m on low RPM on 1st, 2nd shift. I don`t know if its the engine, exhaust or something else but now because i bought this one i don`t wanna repair anymore anything on it ( also i would like to sell it but i have no idea what will be the value of it ) . Its a 2001 MR2 MK3 semi-auto with 110.000 miles, when i bought it it had 98.000. This is how much i`m driving in 2 years :smile:
