Heating / Air con , still on despite being off
gokhan
Hi guys
noticed during the hot weather that even with fans off completely I still get a little hot air or cold if I used air con last , coming through my vents is this normal ???
the re-circulation button stops air coming from front but I can still feel it by windscreen 😐
Normal in every car I've had, CT included. Turning off the unit just stops the fan, it doesn't seal the cabin shut, so you will get a slight flow of air in. I guess it helps stop any pressure difference issues between the exterior and interior of the car. Also you do tend to find that the occupants need an oxygen supply!
