hi can someone help me out ive just put code reader on my 220d and the codes say P0405 and P2002 does anybody know what they are and is it serious many thanks your help would be most appreciated
From memory the 0405 relates to the EGR and 2002 relates to the DPF.
Probably need to clean the EGR and get a forced regen on the DPF.
Doing nothing may well lead to further problems.
thanks mate ill look into that hopefully problem solved once again many thanks.
@normski2 is right.  The manual says the following:
P2002 is quite common and relates to the DPF:
Absolutely correct dpf is p2002
Dpf blocked need cleaning by force regeneration and also will clean egr too
Perhaps give car surgeon a call  in Birmingham will collect and delivery car back as had my is220d done through them.
Could try putting wynes dpf cleaner in tank and taking it on motorway in 4th gear for 30 mins if it's not bad then should clear it
Good luck mate
