I recently had all my wheels off to do a brake check/lubing.  I jacked up on the sill and allowed each wheel to hang on the suspension one at a time to do this.
Since then I have an awful creaking over speed humps. I wonder, should I not have let the suspension hang for whatever reason? Is there a particular bush that may have been damaged? What might be a remedie?
Thanks guys,
Bod
It's perfectly acceptable to let it all hang out.
The suspension doesn't take much to resettle and I wonder if some grease or dirt has been dislodged and moved where it's not welcome.
You don't mention your mileage and if or when any suspension work has been done.
It may disappear or might have unsettled a worn out bush or joint.
My wife'a car developed post MOT a dreadful clatter front end. Dutifully I removed the front wheels and did a visual inspection, pushed and pulled, spun the discs and saw nothing amiss.
No more noise. Bonkers.
She's an old girl with 154000 miles on her. I replaced the front anti roll bar bushes a few months ago but that's all. All was well after that. The creaking came immediately after I had lubed the brake pad carriers and sliders. Most annoying.
  • 6 months later...
As it's a rubber sound, is the brake line flex hose bent wrong way and rubbing? Wouldn't expect it to be loud, but other than bushings and tyres, what else is rubber?
Yep worth checking to see if anything has parted. Mind you metal can sound like rubber when it’s a mind to.
Put it this way I don’t think you’ve caused damage...how about the lower stabiliser bush that does the camber. That gets truly pulled when you drop the suspension.
Thanks for the replies guys. It was the new anti roll bar bushes in the end. I took them out again, lubed them all over with red rubber grease and all is quiet again now.
Sorry to be a pain...they are not supposed to be lubed. Held firm with no slip/movement.
What make are the roll bar bushes? What torque have you applied to the brackets?
I use brake cleaner for getting rid of debris and grit, things that can cause friction and noise.
They might have settled after bedding in.
