hi guys can anyone help me a little while ago I had check vsc done what you guys said and it was sorted ive now had it come on again ive done what was done last time and nothing has changed any ideas, I go away in a couple of weeks and need it sorted without setting me back too much if possible thanks
What did you do the last time?
Do you have a way of checking fault codes?
hi yeh I gave the egr a decoke and ran it at high revs for about 30 mins that seemed to do the trick ive done the same this time and ive give it a run twice now and its also pulling sometimes.
hi yeh I gave the egr a decoke and ran it at high revs for 30 minutes that seemed to do the trick ive done the same this time and ive give it a run twice now and no change plus its started to pull sometimes.
More answers in the IS220d forum maybe?
Have moved to IS220D so you should get a few more replies. Mike.
You need to read the fault codes to see what the problem is.
Do you have a reader to access them?
