Fitting Trd Body Kit To Is200 Auto
I got hold of Tony's old body kit which is a TRD kit. when I look at my car which has never had a kit on it some of the holes where the kit bolts onto are not there at all on my car. do I just need to drill new holes?
the side skirts have lots of holes to bolt it onto the bottom but there is nothing under my car that I can see where the bolts would go.
the front bumper skirt also bolts onto the inside of the front wheel arch but on my car the only thing I can see where it would bolt onto is the wheel arch liner, is this correct?
maybe im missing some brackets perhaps?
Many thanks in Advance
From memory the s/skirts should have about 5 bolt holes and they should line up with thick plastic lug type brackets which are then screwed into these,do you have the front lip spoiler? as this is stuck on(i think)as well as screwed into the archliner.
If it dont fit,do you want to sell it?
ah thanks duncan
Do i also need to drill holes in the rear bumper to fit the rear lip
and drill holes on the sides to fit the side skirts too?
Not sure mate, I've not needed to take them off recently.
You could PM BESTY, he's just fitted a trd rear skirt to his last week.
ah thanks duncan
yeh you need to drill holes in the bumper,best to take it off to do it cause its a nightmare wid it still on. :)
