Can the climate control remember your temperature setting?
A little while back I had alternator failure and so the car was worked on with no Battery for a few days.
Since then I have noticed that every time I start the engine the climate temperature has reset to 22.5 and is off. Unless that is I have only switched off for a brief period, such as at a petrol station.
I'm sure that, before the extended Battery disconnection, the system remembered my settings regardles.
Is there a way to make that happen again - I have looked in the manual but can't spot anything. Oh, and it's a MM system - 2006 IS250 SE-L.
If relevant, when I do start the engine the LED on the middle button under the screen (Front?) flashes orange for a few seconds before the climate controls light up and are operable.
Many thanks.
Chris
No idea how to rectify your situation but yes, In my car, it reverts to or keeps the last used setting. If I have A/C enabled, it'll always be enabled every single time and the temperature and fan speed will be set to whatever I used last.
Thanks for confirming I'm not going mad, and it should remember my settings.
Now just to work out how to get it to do so again...
In my car the a/c settings are registered to the electronic key. If my wife changes the settings they are automatically put back to my prefered settings everytime I unlock the car.
