Hi there.
Recently I've replaced the lock door actuator in a driver's door. As a result the central lock does not feel if the door is locked or not. When press the lock button it locks well. However when try to unlock - door lock opens but when I open the door the alarm activates. When I press open button twice, all the doors are being unlocked and alarm is deactivated (central lock tries to open doors twice where as the doors are already open after first attempt -  I hear the second click inside the doors).
It would be highly appreciated if you could tell me whether it can be fixed by myself or visit to service station is required.
Cheers
sounds like some of the wiring may have been left unplugged. Have you rechecked?
Yep, I did twice. First I also thought that I forgot to connect something.
I'll have a look at the wiring diagrams later and see if there is anything obvious.
Really appreciate that
