Tyre Pressure Change 2017/18
Lowered mine to 36psi from the 40 psi set by the Dealer & cannot find out how to initialise the new setting as there is no longer a Dash Button.
Can anybody help please ?
Tel
I had a similar problem last year. If you search for TPMS button you should find the the post I raised on the 20th July 2016. If you follow it you will see a photo I posted of where to find the TPMS button under the dash. Hope this helps.
Rayaan is right as my 36psi setting all round did not result in an alarm as the System clearly measures the fall from any set value .
Thanks to Peter, too, for researching the 2016 post.
Tel
