Sorry? What do you mean by legal hour? If you mean GMT summer time, then yes that is set. That's what makes the satnav show the correct time. Bit it's not changing the call history times.
May be there is something to fix in phone then...
Nope. Tried 3 different phones, Battery disconnect and even full personal data clear. It seems that the time for calls is in sync with the GPS clock and amending the Summer Time setting has no effect on it. I'm interested in know how people car changing the time and date as there is no options in the nav system to do this. You can only select time zones.
I set the date within the calender, when you select a date there is the option to 'set as date'.  I'll get a photo next time I'm near the car
Please if you can. What nav system have you Got? USB or non USB?
Need mine doing as well its 1 hour behind.
On a side note how do you transfer your contacts from your phone into the Nav system?  I have a Galaxy Note 3.
Do you need a special app?
Is your phone time stamp out of date?
I've got a s7 edge and has no issues transferring my contacts
Phone time is correct, screen just says transferring and stays like that.
Maybe Im not giving it enough time.....
I'm really confused now why the time stamp on dialled and recieved calls is 1 hour out! It's been working fine last year and year before that with no issues.
I have transferred mine with no issues. Takes about 3-4min.
Do you mind taking a pic of your nav system and where you set the date pls
