Hi all,
Does anyone know how to change the date and time on the navigation system? It's on the pre facelift version I want to know. I've looked at the manual and found the time zone setting but even adjusting that it's not correct. It's bugging me bigtime!
1 hour ago, Arqum said:
Hi all,
@Arqum Arqum I thought the clock was auto sync with gps. Or the only other thing I can think of select off in the 'adjust clock' screen for DST this will correct the clock for the time of year... hopefully 😏
Big Rat
I did try that but my call time stamp is still an hour out. Also where do you set the system date?!
No worries. I've looked in the manuals but can't find anything meaningful
Hi mate did you get a chance to look?
Hi mate,
The way i fixed mine as the Nav arrival time was an hour behind the dash clock,  was to go to Settings, Clock, Daylight Saving set to Off. Go into time zone and click Other and manually adjust the hours. Just done mine and clicked + 1hr. Does it in half hour increments.
Mike
Does it also sort the time on your phone call list? Still can't work out where it picks the date up from though?!
Ahh pass , ive never bothered to connect the phone.
That's what is the most annoying being 1 hour out. Still also can't work out how is the date set?
@Arqum I'm sorry mate I'm working away with the vans at the moment, I'll look as soon as I get back, had to leave Sunday instead of Monday 👹
Big Rat
No worries mate. I know how work can be.
update on this, the time issue for the Nav is sorted but the call times are still out... Any ideas?
@Arqum Sorry matey I looked at this last nite and read through my manuals and messed about with car, I'm none the wiser to help - 😐
is your time for both nav and phone calls correct then? Or are the phone time stamps 1 hour behind?
There must be something I am doing wrong then!!!!
@Arqum Is there not a Lexus dealer travelling distance from home, sure there would be someone there who could help, maybe even for free😇
Big Rat
gonna drive to one after work today and see what is going on? Its really doing my head in as its been fine before!
tried with my Iphone,S7 Edge and Note 5, all the same issue. Reset the nav system too by deleting all personal data :(
Must be something strange, I've just purposely changed my date and time, call logs updated and when i put it back to normal it is ok again
How did you change the date?!? I have no option to do that!
So went to the dealer and they are none the wiser on why the call times are 1 hour behind. Nav is showing the correct time. How are you changing your time and date as I cannot see any options to do this apart from the time zone settings.
