Rx300
Andy2905
Hi Andy, welcome to the LOC and supporting the club as a gold member.
If you can find a good working OEM system you could install this but it would be dependant on whether the last owner chopped the original wiring or used adaptor cables.
If you have a local auto electrician it may be worth asking if they can sort out what you already have or advise on refitting an original set up.
Also bear in mind the OEM system will probably not have Bluetooth if you wish to use this source.
