Hi All,
Ive changed my RX400H's all break pads myself. They are all working good now.
I remember when I was changing rear break pads  one of the bolts have small black bush at the end. I dont remember if I put it in right side when I put it back . Is the one with bush goes  on the top or bottom hole of the calliper? If I got it wrong  wrong side ,  will it be problem later on or not? What is the bush for anyway and why two different bolts are used for?
see attached photo for the bolts.
Front one has pins instead of bolts and one of them has bush at the end. Same question is asked here please?
dagva
The bolt with the bush should be used on the lower mounting point on all 4 callipers
Dou you have a PN for the bolts please, mine need replacing
I got mine from Lexus Birmingham on eBay just put in your car details and you'll find them.
Genuine Lexus RX300#2, RX400h & RX350 Rear Caliper Pin & Boot Kit
£18.99 for the two.
