It's right up above the pedals, is clipped to the firewall and runs out through the firewall.
I think this is also leaking. I have traced it back as much as possible and seems to run up the A pillar alongside the sun-roof drain.
Only a guess but if it's carrying water it may be the washer feed to the rear window?
Confirmed, when using rear washer you can see bubbles flowing through this tube
Thanks very much, one down in the process of elimination.
