I have a 2000 Mk 4 and I have an intermittent red Brake warning light flashing , with a message saying " Brake Wear".
I took it to the Garage yesterday and naturally ,the light stayed off! He plugged in the computer and ran diagnostics,Nothing.
Checked brakes manually, on ramp, fine.Any ideas,Chaps?
probably just a back stop light bulb playing up !  it's been there 16/17 years and I know it's a failing of Lexus and mine only last about 16 years before they start to fail :yahoo:
Henry
Check the connector at the brake pad warning wire ,take it off and give it a good cleaning and a spray of wd40 when re-fitting.
I agree with Malc. It's the stop warning light
moonraker/henry .......  issue resolved now ?
I think this can also be caused by slightly low brake fluid level in the reservoir.
