Hi all,
Im in the process of buying(not sure) a LEXUS RX 450H SE car  - 55k miles, 2010  - 3456 cc
But the car wont start - Dashboard blacked out
Im guessing its the Battery but not sure
I just want to gather your opinion on how much it will cost to fix assuming it has a dead hybrid Battery ?
 And list of problems that could be wrong with the car from electrical point of view - Ill assume petrol engine is ok
Many thanks
Sounds like the small 12v Battery needs charging/replacing as that should initially fire up the dash and computers that control the hybrid system.
Has the car been stood for a while and not used?
17 minutes ago, Rx300-SE said:
Hi all,
Im guessing its the battery but not sure
I just want to gather your opinion on how much it will cost to fix assuming it has a dead hybrid battery ?
Many thanks
It wont be the hybrid Battery - more likely to be the 12V one.
Id steer clear of the SE though, its not exactly loaded to the same level as an RX300 SE
I agree on both counts. You will be missing out on a bunch of extras with the SE, and I would go as far as saying that it will make resale difficult.
See attached.
Lexus RX Series III.pdf
16 hours ago, rayaans said:
It wont be the hybrid battery - more likely to be the 12V one.
16 hours ago, Farqui said:
Sounds like the small 12v battery needs charging/replacing as that should initially fire up the dash and computers that control the hybrid system.
Yes, I think its been stood for a while . Thanks
