A few times lately when starting up in the morning a message has briefly appeared on the centre screen ' Validating SD card' or similar.
Does this mean that the car is checking that the sat nav micro SD card is kosher?
Mind you yesterday the sat nav guided me away from an overturned lorry on the M5 and tried to put me back on 2 junctions further up where the problem was !!
below the cd / dvd slot on the vertical surface there is a panel that lifts up under this panel is the sat nav SD card.
