Hi gang,
A little advice please. I have code P0430 Catalyst Working Below Efficiency Bank 2. Can anything be done i.e Italian tune up, or is a new Cat required?
Thanks,
Bod
Don't Panic. More often than not it's a sensor failure rather than a component failure. You just get the error because the computer is not receiving data from the faulty sensor.
Ah ok John, which sensor should I be looking for. Here's the history.
When I bought the car back in August, the CEL was on and my code reader showed 1 fault that being Bank 2 Sensor 1 oxygen sensor heating element not working.
Like a numpty, I left it until now to change the sensor. I plugged the reader in to confirm I was changing the correct one, only to find I had two codes. I changed the sensor and cleared the codes and started up and the CEL stayed off. Then after 10 miles today the CEL came on again with code P0430.
Bod.
Bod.
You'll have to find someone clever to tell you that, which I'm afraid is not me. :)
Thanks Garry.
I know, it was silly really. I only left it because the sensor itself was still working when warm as only the heater element was broken. Lesson learned.
Here we go again with trying to second guess a rectification path.
Bod
P0430 = catalyst bank2 below threshold.
There is a bodge fix for this. If you disconnect the Bank2 O2 sensor wire where it goes into the ECU and connect this input to Bank1  O2 sensor the system sees a good input for both banks "the Bank 1 sensor", and regulates the fuel accordingly.
Replacing the O2 sensor for Bank 2 is the correct course of action if the problem still exists the cat is suspect. A cat cleaner and a fast run "may" cure this.
John
That's great John. I didn't even know that cat cleaner existed. I'll get some tomorrow and go for thrash. Seems like a good place to start.
I changed sensor 1 already. I may have to spend another £35 on another one. Lexus wanted £180 for one. LOL.
Thankyou.
Bod
