My wife's 2009 rx450h has developed an intermittent power steering problem . The check power steering light comes on and the steering becomes very heavy as in undriveable and very scary when it happens . Switching off engine and back on again brings the power steering back into operation but doesn't last long. First time it happened twice about 2 weeks ago then seemed OK until a couple of days ago when it was happening almost  constantly . Managed to drive home with a lot of stop starts  and called recovery who admitted he had no idea about hybrids but suggested possibly a sensor of some kind , electrical fault , maybe ecu unit, maybe bit of dirt , maybe an earthing issue . In other words he didn't really know . Car has covered 125k miles has a full lexus history but is out of warranty . I really don't want to get it towed to Lexus dealers who will No doubt rob me blind . Phoned my local mechanic who has recommended an electrical specialist so booked in for diagnostics next Monday . My question is should I be selling one of my children to pay for likely repair cost ? Anyone had similar experience or any suggestions ? Cheers
Have no experience of this but have you tried the USA owners website because there are far more of these vehicles over there.
A Lexus main agent will have full Toyota Techstream software to read any codes stored and that would be my starting point.
Thanks Graham . I did have a brief look and came across some mention of a similar problem but the issue seemed to be related to interference caused by installation of aftermarket HID lights . Not the case with my wife's car which is standard lights . If the local guy can't diagnose will have to go to dealers but have had a few run ins with them before so would rather avoid if possible . Cheers , Kev
Update : local electrics specialist has advised that car needs a complete new steering column . He stated it is an internal fault showing as a torque sensor but says that is integral to the motor and is connected to the power steering ECU so am now in position where I bite the bullet and put into dealers ( cost of power steering column quoted as £2,800 inc vat but not inc fitting or trying to source the correct parts second hand . This local guy would fit a second hand one but suspects it would need coded by Lexus and may well immobilise the car so doesn't sound like a great option. Also not sure of the part number for steering column . Any suggestions as to the way forward ? And any assistance with part numbers appreciated .
Oh dear, that sounds a bit of a sore one. Hopefully someone on this forum could tell you how feasible a second hand one would be. Can't believe how technology has marched on and that a steering column needs coded to a car. The price of technology. I've just bought my 2010, I think I will spring for an additional 2 year warranty for £1000, it may well be a good investment.
Really hope you get a reasonable quote to fix it.
Ed
Ed
Thanks Ed . Car was towed to Lexus Edinburgh today so will see what they come up with but not expecting good news.  Yes the warranty sounds like a bargain when faced with repair costs like this one totally out of the blue. Am now thinking of getting one for the ISF . Cheers , Kev
  • 2 years later...
Although yours is an old item from January '17 can you advise as to how you got on with Lexus Edinburgh as I this has happened to me on a couple of occasions.  When it has happened it has been very short, no more than a second or two and I have not noticed a warning light.  I am not aware as to whether these instances from a few months ago will be in any ECU memory.
I have an extended warranty and would be glad to know how you got on before I go to a dealership.
Cheers
Dave
Hi David - Lexus did diagnostics and all they did was update software and that seemed to clear the problem - was pleasantly surprised with the bill of around £250 since I was at their mercy really having no warranty and was expecting the worst ! Sadly my wife had lost confidence in the car and we traded it in a month later  . I would think you should be ok with warranty - certainly hopefully you get it all sorted since pretty scary when it happened .
  • 4 years later...
Hi.
I was jus wondering if the fault with your RX450h was fixed. and what was the fix in the end?
Lexus dealer carried out some kind of software update and that seemed to sort the issue but like I said above my wife had lost confidence in the car so it was traded in a month later . Hope that helps .
