2 hours ago, frankcnwl said:
I turned it on and nothing happened except the my AC/DC 14V transformer started smoking.
I then tried it with another car battery charger and that didn't work either.
Depending on how flat your Battery is, you may need to leave it charging for several hours before you are able to open the vehicle. Don't connect a Battery charger than is rated for over 5 amps, the vehicle's wiring to the bulb isn't designed to carry a large current.
