For the rattle that goes away when the clutch is depressed, you can also try changing the gearbox oil as the gears can also make a slight noise when not under load.
It's been identified as the clutch release bearing, will be going in soon to have it replaced and have the dpf and clutch plates inspected at the same time and if need be renewed, all covered under extended warranty apart from the clutch plates which I will pay for.
