Whilst on my hunt for info on the LS460 prior to purchase I came across this list of configuration customisations, i.e. options that can be set by the dealer or via one of the many OBD tools available.
Thought it may be of interest to others...
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
YES / NO
Volume of beep when locking/unlocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
Warn (beep) when door can't be locked because it's still open
YES / NO
Panic function on remote
ENABLED / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
YES / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key/button
ALL DOORS / EACH DOOR SEPARATELY / DRIVER'S DOOR / SAME-SIDE DOORS
Auto-lock doors when moving
ON / OFF
Lock doors when shifting into gear
ON / OFF
Unlock doors when shifting into park (P)
ON / OFF
Unlock all doors when driver's door is opened
ON / OFF
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / ANYWHERE IN VEHICLE
Unlock trunk when smart key in range
YES / NO
Open windows and sunroof by holding key in door lock
ON / OFF
Close windows and sunroof by holding key in door lock
ON / OFF
Open windows and sunroof via long-press on remote
ON / OFF
Close windows and sunroof via smart key
ON / OFF
Auto-arm the alarm when door closed with key NOT in ignition
ON / OFF
Delay for auto-arming alarm
0 SECONDS / 15 SECONDS / 30 SECONDS
Beep horn when auto-arming alarm
ON / OFF
Open/close power rear hatch via interior switch
ENABLED / DISABLED
Instruments / Display / Dings:
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / OFF
Key-in-ignition ding volume
LOW / MEDIUM / HIGH
Key-in-ignition ding sound
SLOW / MEDIUM / FAST
Ding when headlights are left on
YES / NO
Seat belt warning
DRIVER AND PASSENGER / DRIVER ONLY / PASSENGER ONLY / OFF
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / 5 FLASHES / 7 FLASHES / 9 FLASHES / 11 FLASHES
Remote low Battery warning
ON / OFF
Front parking sensor range
NARROW / WIDE
Rear parking sensor range
NARROW / WIDE
Mute parking sensor when stationary for more than 3 sec.
YES / NO
Activate parking sensors in neutral (N)
YES / NO
Front side parking sensor range
SHORT / LONG
Enable front parking sensors when in reverse (R)
FRONT / FRONT SIDE + CENTER / FRONT SIDE / OFF
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / OFF
Auto-turn off parking display when moving away from obstacles
YES / NO
Dash display mode
ALL / UNDISP
ECO Drive indicator zone
ON / OFF
Lights:
Daytime running lights
ON / OFF
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
ON / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when you unlock doors
YES / NO
Turn on interior lights when smart key in range
YES / NO
Turn on exterior footlight (on side mirror) when smart key in range
YES / NO
Interior footlight (bright when doors open, dim when driving)
YES / NO
Center console spotlight (bright when doors open, dim when driving)
YES / NO
Turn on seatbelt-buckle lights when door opened
YES / NO
Turn on seatbelt-buckle lights when ignition turned off
YES / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
YES / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
YES / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / 30 SECONDS
Interior light control
ENABLED / DISABLED
Exterior light control
ENABLED / DISABLED
Advanced Illumination System pattern
PATTERN 1 / PATTERN 2 / OFF
Heater & A/C:
A/C power
AUTOMATIC / FULL POWER
A/C ECO mode
ENABLED / DISABLED
Auto-increase blower speed when front defroster is on
YES / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / NO
Deactivate front defroster when AUTO button pressed
YES / NO
Also blow to feet in "face" mode
YES / NO
Auto-activate steering-wheel heater
YES / NO
Auto quick seat heater (front left seat)
ENABLED / DISABLED
Auto quick seat heater duration (front left seat)
STANDARD / SHORT / LONG
Auto quick seat heater (front right seat)
ENABLED / DISABLED
Auto quick seat heater duration (front right seat)
Other:
Roll down rear shade when in reverse gear
YES / NO
Delay for rolling down rear shade when in reverse gear
IMMEDIATE / 0.7 SECONDS / 0.9 SECONDS / 1.2 SECONDS
Move driver's seat lumbar support for easy exit
YES / NO
Move passenger's seat lumbar support for easy exit
YES / NO
Lord.. that's very comprehensive
Sent from my iPad using Tapatalk
