Caliper slide pins kit
Rubin85
Hi
I tried to replace caliper slide pins including rubber dust covers, unfortunately the size of the rubber dust is different than the diameter on the caliper, I couldn't fit it, I've damaged 2 of them already :/
The size of the rubber is 17mm where the caliper only 15mm. I bought them directly from Lexus, not sure if there is 2 sizes available.
Any advice ? Appreciate in advance
Assuming front callipers I can only see one part number for the bush fitted to the top slide pin part number 47769-50010.
Part numbers for the top and bottom pins are different
Top 47715-22070
Bottom 47715-52190
