Hi
I have an IS300h f-sport which has the "LFA" style gauges. I have noticed on many models that when the main dial is moved to the right and the "i" tab is selected it appears information such as fuel economy etc. However, on my car it just displays a blank screen on the "i" tab. Does anyone know how to change this? See attached image.
Odd, but probably worth a dealer trip. Perhaps a software update would sort that or they might have to stick a new cluster in
And yes, it should show the mpg etc on that screen
Maybe I'm missing something, but if you use the down arrow on the rotary dial on the right side of the steering wheel, doesn't that then show mpg etc? Perhaps I've misunderstood the post.
Arrrrhh! just tried what DJP selected and  Voilà it works. Thanks! It will teach me for being a .........:wallbash:
These cars are so complicated. You either need a 7 year old assistant or a couple of weeks to learn the 1100 pages in the manual
I've never read the manual and coped fine. It's just a matter of going through everything and experiencing it.
You can read whatever from a book but you won't remember it till you do it
My problem is that due to advancing years I work out how to adjust something and then forget it next time. Mind you I change my car every 9 or 10 months and they are all different.
I know what you mean, sometimes I find a way to change something but because it's been trial and error I've forgotten how I did immediately.
If you scroll to the right to settings,  you can change what is displayed in the "i"  tab and the order too.
