Small things to improve.
I put my remote in the centre cup holders  along with odd coins . The plastic bottom isnt very lexus and the storage bin has foam, so i cut some plush foam to size and placed in bottoms, much better.
noticed a little rattle on every drive thats been annoying. The culprit is the passenger seatbelt clip rubbing the hard plastic b pillar while driving. Other cts must do this?. Surprised lexus havent solutioned this. Im goin to place a thin strip of foam across the parts that rub. Simple but improved.
just noticed the driver and passenger door grab handles are different too. Still finding things lol.
Interesting you say about the passenger seatbelt as I have this too and like you say it's very annoying because it's the only rattle in the car.
I have a mysterious rattle also, will check if this is the cause.
Sent from my Nexus 6P using Tapatalk
Just placed a thin black foam strip across where the clip sits. Test drive tommorow but it already works.
Thar, theres so little room between the bpillar and seat squat im guessing all ct's will rattle without a passenger.
i have a little of this foam left and quite willing to pop a bit in post foc if it helps someone out. Its black so doesent stand out and easily removed .
i have used self adhesive felt before to stop this rattle and its only 1mm thick so its really unobtrusive
