I play my music through the stereo from a memory stick.  Works fine apart from it often reverts back to the first song on the list as opposed to carrying on from where I left off after the ignition is switched off and back on again.  Can anyone help with a solution for this?
Check that you're on the latest software. Mine used to do that until I updated it
Thanks for the reply, and sorry to be a pain, but how do you do the update?
I think the latest one is on the Lexus service pages and you need a special bulletin code to put into it.
You can only do it if you have premium nav
The normal nav requires an update by the dealer which will be free if you say it's laggy
The link posted above is still the latest available software version to date.
