P0420 cel on my 2002 rx 300. Help needed
I bought this car about 3 weeks now and it's throwing P0420 code.  I had the freeze frame screen shot on my torgue Bluetooth scanner attached.  I need the techs in the house to try to decipher what the problem could be.  I am also adding pictures of my oxygen sensor and af sensors scan tool data.  I need to solve this code quickly as it's affecting my fuel consumption
You are in closed loop, the vehicle hasn't switched to using the O2 sensors to adjust trim.
You also need to let it complete a few drive cycles as you reset the error codes so it is showing some data as 'incomplete'.
