The ls400 ive newly aquired  wont start after the Battery went flat. The red security light is flashing even when the keys turned. Does that mean its immibolised
Yes it is immobilised. What you do is
the ignition switch must be left in the 'on' position for 6 minutes and then turned off before attempting to start. Same procedure in a flat Battery or Battery disconnection.
thats the info from my manual...
thanks for that simon . i found it just after i put this. started straight away
