have a problem on my 2007 is220d all the windows work fine separtly but wont work of driver door control unit ,except for the drivers window?
are the rest of the windows on a different fuse? any ideas.... thanks
  • 3 months later...
Had this problem with my GS300, and that was without the battery disconnected for any maintenance.  It occasionally keeps on happening too. Turning the ignition off and then switching it back on seems to cure the issue when it occurs.  Never got to the bottom of it.
