I'll be doing a coolant change soon and will either use Halfords posh pink ready made up stuff (good for 6 years), or Toyota Genuine stuff. The problem is this is so expensive in the UK, compared to the USA.
Anyone know of a more reasonably priced outlet for it? I have used Halfords before very successfully.
Hi
I used Eurocarparts for neat pink long life. It's OATS and all so is perfect. They have some very good offers on and that might make for a good deal.
For the water I was lucky with 5ltr distilled at only £1 yes one pound only on a Halfords offer.
Worth shopping around.
I wasn't sure if the pink OATS stuff was chemically the same as the genuine Toyota stuff? Has anyone ever found authoritative advice on this?
Hi
there is some info in the handbook I believe the spec refers to G5. or similar. Oats means it's ideal for alloy and essentially doesn't contain nasty stuff. I would opt for long life as this is a Lexus requirement: complies with their service intervals.
one can run around in circles on this...as with oil...
you can always buy from Lexus if you'd rather. Sometimes prices are surprisingly ok.
What I want to do, is have a good power (hose) flush out of the radiator (reverse flush etc) and other stuff. Drain, fill up, and go for a 3 miles run, and then drain, and put in the ready made up stuff.
I suspect neither brand is super critical, but would like to find a cheap Toyota supplier.
How long does the Toyota/Lexus stuff last?
I get Toyota red concentrate 5 litres for £22.00 at my local Lexus dealer, lifespan is 5 years.
