My new purchase seems to steam the screen up any time  i put the fan on. It doesnt happen when air con is on.  Ive had a few cars do this . Surely it cant be right
Quote
Look at the cabin pollen filter. If this are gundgy they often clog up the air flow. Air-con will usually clear anything.
John, I've had this problem recently too, so I replaced the pollen filter,(easy Job on an LS). One thing I've found though, and this applies to any car; I never use the Recirculation button without the A/C being on, because when it is raining, being in Recirculation mode without A/C switched on will guarantee you a quickly fogged up windscreen. Recirculation mode is only safe when it's not humid outside or it's not raining. In fact I found that the A/C works better with Recirculation switched on. Having only outside air to the vents i.e. Recirculation off, also stops fogging up.
I tried all settings but it only clears when the air con is on.  Ill change rhe filter.
hhmmm  ...... open the windows sometimes maybe :smile:
It could also be damp getting in from blocked sunroof drains or from the front doors by the tweeters, or perhaps you're just a moist fellow!
John - I'd not changed the pollen filter - that might be the cause.  I never had steaming up though - but just remembered that the HVAC had begun to default to recirculation on when the car was started - which it never did before. Sorry I forgot to mention this.  Hope she is otherwise well!  Tom
