Ron, A failing Battery is the more likely cause (but not the only one). I've had the same lights come up before on my motor whenever voltage is only slightly too low, (even though the car starts fine). New Battery cured the problem. Also, check the output of the alternator; should be good though, they seem to last for ever. You should see around 14 volts with the engine running. The VSC and Trac lights should go off after a few miles once enough voltage is restored. I've learned that these cars need their electrical supply to be at its peak at all times.
Thanks guys,
As usual, a font of knowledge !
The Battery is quite new and has not been removed, the light came on just as I eased off after a hard acceleration, ( can't resist showing off once in a while, LoL )
Think I'll take her to my local and have the output checked.
Cheers all.
