ABS LIGHT ON
Jason rye
Hi i have a problem with 1 of my lexus is200. I have 4 of them now lol. I have the abs light on iv plug it up and its not telling me what the problam is.No engine management light on. Can sumone point me in the right direction what to check. Iv pinned it out pin13 and 4 i cant remember off the top of my head which pins it was iv got the right one wrote downwhere. When iv pinned it out the ABS light flashed and 3 bleeps sounded. But the ABS light still stayed on. So i dont no where to go from here with it. So i hope sumone can point me in the right direction. thanks jason
i havent got the TRC light on just the ABS light
One of the wheel speed sensors is the common cause, check the wiring to each one and the plug connections.
You can also measure the resistance of individual sensors which is normally around 1000-2000 ohms.
Other causes are a damaged toothed reluctor ring mounted on the hub or the build up of dirt on the wheel sensor head.
I don't understand why diagnostics have not picked up a code as this would have pointed you normally to the faulty sensor.
