If I remember correctly the pipes cannot be seen just by looking under the car, you have to get underneath, but they are in the location ambermarine mentions.
Can't see it and I'm right underneath it, is just the one pipe? I can see what looks like a drain pipe but there is one the other side that matches it.
According to the exploded diagram there should be 2 drain pipes fairly close together, passing through grommets to the underside of the car, exiting somewhere around where the engine and transmission meet.
I read on one of the american forums that they don't hang down but are hidden by the heat shields, find a hole in the heat shields and you should see a grommet type hole, or maybe two.
I'm writing this from memory, can't find the writeup, sorry.
Thanks for all the help. I took it for a run and it dripped from both pipes afterwards. I was looking at the correct drains and there are two one on the nearside and the other offside in the same place near the sills, two grommet like drains as was mentioned but in full view. I'll take a picture and post it as it may help others.
