I'm having my throttle body cleaned to try and improve throttle response and mpg, and having read some posts on here, I was thinking about changing the coolant temperature sensor, thinking it was a cheapish part. I have been quoted around £60 for the snsor at the main stealers, which is much higher than I expected. Is it possible to get pattern parts, anfd if so are these satisfactory?
Hi
I recently changed spark plugs, air filter and adjusted the slack out of the throttle cable.
This has transformed the speed, pick up and sharpness of the engine. I have noticed the difference.
only thing I would caution is that throttle bodies have a layer of protective coating and unless sticking or faulty are best left alone.
My mileage is 78k and there is nothing on the butterfly...or at least not enough to warrant touching.
  • 1 month later...
On 22/07/2016 at 10:28 PM, steve2006 said:
If you can wait a short while the Amayama price for this part (89422-30030) is £22.37 plus shipping.
Steve
How sure are you that this part number will fit a 1999 ls 400? I have seen some on eBay uk for around £25 , quoting that part number, but the compatibility chart states that there are 7 other variations?
Hugh
The temperature sensor is very important to the correct fuel mix on the engine management system I put a new one on my Mark1 after a period of time when the revs were too high for two long a period.
It is there to monitor the fuel to air mix required for optimum performance as the engine runs up from cold.
The aftermarket cheaper versions may not be as sensitive therefore defeating the object of having it renewed.
I found that after fitting the Toyota sensor bought whilst in the states( it is fitted to most of the toyota range also) the engine ran a lot better from start up to optimum running temperature and was well worth the extra cost.
Part 89422-30030 (SENSOR, WATER TEMPERATURE (FOR E.F.I.)) was found on the following models:
  Date range Model Frames/Options Found in diagram
  01/1999-06/2005 LEXUS IS200/300 GXE10,JCE10 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  05/2001-06/2010 LEXUS SC430 UZZ40 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  08/1997-12/2004 LEXUS GS300/430 JZS160,UZS161 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  01/2005-11/2011 LEXUS GS30/35/43/460 GRS19*,URS190,UZS190 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  10/1994-07/2000 LEXUS LS400 UCF20 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  08/2000-07/2006 LEXUS LS430 UCF30 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  01/1998-07/2007 TOYOTA LAND CRUISER UZJ100 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  01/1998-07/2007 TOYOTA LAND CRUISER HDJ100,UZJ100 84-04: ELECTRONIC FUEL INJECTION SYSTEM
  08/2002-07/2007 LEXUS LX470 UZJ100
Thanks for responding chaps, I think you make good points, the sensor being such a critical and sensitive part, it may not be a good idea to economise on its replacement. Tempting when you see the same part for less than half price. No idea what intermotor parts are like, I understand they are OEM on some cars, but perhaps not worth chancing it
  • 4 months later...
Gents,
I've no record of the coolant sensor being changed, should I go ahead and change it regardless?
I read somewhere about a fuse needing to be removed/reseated after changing the sensor but can't now find that thread.
Needed?
51 minutes ago, cornershop said:
Yes indeed, but can I check it's not broken. I've read it's an important sensor, what would be the symptoms of failure?
Difficult starting when hot, uneven running/revs, completely cutting out and many other problems.  It's amazing what one little sensor can affect.  I wouldn't waste my money unless I had a problem, they rarely play up.
Shirish
Main symptom of a temp sensor malfunction is high revs for prolonged period after the car as been started from cold.
The car starts and runs at about 1100 revs initial start up A/C off it eventually falls back to normal tickover of 650 rpm as the engine warms to normal if the revs stay above that 650 rpm at around the 1000 to 1200 rpm area the sensor as failed.
This will be apparent at starts from stationary as the transmission will clunk when putting the stick  in drive from park.
On 14/01/2017 at 1:16 PM, alien1974 said:
what fuel are you using? bare in mind the manual says 96 RON or higher, i use either 97 super unleaded or 99 tesco momentum
LS400 mk4 manual says 95 or higher but ok for temp use of down to 91.
