AEZ Alloys size to fit mk1 is200
Ace-1
hi im new here , i have been offered a full set with new tyres of AEZ alloys. my y plate lexus is200 is stock no mods
its the wheel size i would like to know if would fit onto my is200 here are the new wheel sizes ::215/45ZA17/91w  pcd=ET49 PCD 108..
If anyone has experience of these sizes going on a mk1 y reg IS200 please help me out much appreciated . Hope this is correct place to post thanks in advance
Hello and welcome to the LOC
Unfortunately those wheels will not fit on any Lexus model as the PCD needs to be 114.3 and 5 stud, normal offset (ET) is 35-45.
A lot of Japanese makers use the same as Lexus.
Hi and welcome to the LOC, we are a friendly bunch and some of us even know how to pull them to bits and put them back together again, with of course the one bolt and washer left over.
We always like to see pictures of members cars so don't be shy.
We recommend you spend a couple of mins looking over the rules of the LOC, we will be asking questions later.
http://www.lexusownersclub.co.uk/terms-conditions/
Regards Mike
I would like to thankyou for reply , i never knew what pcd even meant they are 5 stud the freind
says i would need spacers so i said yeah metal no said rubber or plastic. these wheels are spanking
its a shame . cheers steve2006 , bluesman for welcome . Im off to learn about pcd
Is it possible to use spacers or spigot or any other modification to get these alloys on safley ?? alloys that i want to fit are  215/45ZA17/91w  pcd=ET49 PCD 108..  is there a mod to alter the existing pcd on lexus to that of whitch needed??
Edited by Ace-1
PCD stands for Pitch Circle Diameter which basically is the distance between the holes in the wheel where the wheel nuts fit.
Wheels with a PCD of 108 will not even fit on the hub of a Lexus as the studs will not line up to the holes in the wheel.
You can get adaptor plates but personally I wouldn't trust them to ensure my wheels were secure.
Spigot rings, in the centre of each wheel is a hole of a certain diameter called the bore, on Lexus this hole needs to be 60.1mm. If the wheels have a bore bigger than this you can buy spigot rings to reduce the original size to 60.1mm but you need to know what the bore is to get the correct spigot rings.
I recently bought some wheels and the bore was 72 so I had to buy some spigot rings 72 to 60.1
Offset is basically how far the wheels stick out of the arches and how close they are to the suspension inside the arch.
